New toys came in today
Install on this stuff is amazingly simple. All the sensors run on Racepak's V-Net system, they use standard sending units that plug into Racepak Modules that "stack" on top of each other. Add 12V+ and ground, run your driveshaft RPM sensor and the "record" switch and youre done. Ill take some pics along the way, right now Im mocking up and mounting to determine cable lenghts that I need to get.
Robbie - the engine is no longer SI.
