Drag Racing Tech
What tire pressure you guys run in your ET Streets ?
Old 03-23-2010, 09:27 PM
Mac 2002 SS's Avatar
Default What tire pressure you guys run in your ET Streets ?
Hey Guys,
I just bought a set of 275/50/15's M/T ET Street Radials mounted on set of Summit Stars and I was wondering how much tire pressure do you guys drag race with ? My mods are in my sig . Thanks in advance .
Old 03-23-2010, 10:14 PM
second_2_none's Avatar
I always go down to 16psi.
Old 03-23-2010, 10:37 PM
ls198's Avatar
Same here about 16-20psi cutting 1.6 60". I ran an 11.91 at 114 on ZR1's and if you can get your 60 ft down you should be hauling even more. Good luck. P.S. I love my MT's I have put over 3k miles on them and still look brand new and they have been on my car for almost 2 yrs. Maybe I got an awesome batch but I doubt it.
Old 03-24-2010, 12:11 AM
Restricted User
Zero4488's Avatar
lower the tire pressure until you have the biggest contact patch you can
Old 03-24-2010, 01:45 AM
98_LS1's Avatar
Start at around 16 psi and work your way up until your car starts to not hook well and then step it back down. You want the most psi you can get w/ the car still hooking.
Old 03-24-2010, 08:00 PM
Mean87SS's Avatar
I normally run about 18...
Old 03-28-2010, 06:38 AM
2000SS1979's Avatar
I always run between 15 and 19PSI depends on what the track likes that day.
Old 03-28-2010, 07:03 AM
SS Enforcer's Avatar
+1
Thats the way to do it IMHO I think around 22 psi as that was my best run. You will get a better mph with more psi so if it hooks keep adding it. Carrying a small amount of wheelspin off the line doesn't hurt em either as long as your not blowing them off.
cheers
Old 03-28-2010, 07:54 AM
02 wife's Avatar
I have run 22 pounds with my et streets radials!
Old 03-29-2010, 07:27 AM
LS1TECH Sponsor
Jon@BruteSpeed's Avatar
I run 18 lbs with the radials.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old 03-29-2010, 08:56 AM
brandoz28's Avatar
i run around 18 as well
Quick Reply: What tire pressure you guys run in your ET Streets ?
