Drag Racing Tech
Formulas with 28x10.5 tires pics please
Old 03-24-2010, 12:32 PM
AChotrod's Avatar
Default Formulas with 28x10.5 tires pics please
Just wondering if you needed to mod your wheel wells for 28x10.5 slicks. I know Camaros and TAs need some trimming but what about a Formula???? I had 27x10.5 QTPs and they fit just fine with room to spare, now im putting on 28x11.5 QTPs and they are about the same size as a MT 28x10.5 ET DRAG, maybe even a tiny bit smaller.
Old 03-24-2010, 03:35 PM
DiabloFormula's Avatar
Get yourself a big hammer and start pounding away, you'll need to cut your bumpstops out and those et drags will rub the back bumper as well.
Old 03-24-2010, 05:44 PM
DopdBrd's Avatar
I had 28x11.50R15 ET Streets on my 15x10 6.5" BS wheels and they fit fine. My fenders were already rolled but they cleared.
If you are running them on a 8" wheel I think you will be ok. Their tread width is something like 8.6", which is way smaller than a 28x10.5 ET Drag on a 10" wheel.
EDIT: Nevermind, I didn't know those QTP's ran soo much wider!
Old 03-24-2010, 05:50 PM
DopdBrd's Avatar
Mikie, you still plan on running those on a 8" wheel?
Old 03-24-2010, 05:53 PM
AChotrod's Avatar
The 28x11.5 QTPs are thinner than 28X10.5 ET Drags. I put them side by side both new. They were about 1/4" wider which I thought was strange considering the 11.5 vs 10.5 rating. And yes they are on a 8" rim with 5.5 bs.
I should quit being lazy and just go put them on and find out. They are already mounted and 2ft from the car. lol
Old 03-24-2010, 06:54 PM
airfix's Avatar
Get of ur *** and find out lol, take some pics too. I've been wondering the same thing for the last couple months If mine are gonna rub 28x11.5 et streets but I've also been to lazy to put them on the car. I know you've been waiting too, but finally the nitrous outlet stuff is in shipping.
Old 03-24-2010, 06:57 PM
AChotrod's Avatar
About damn time it shipped!! If I wasnt at work Id go do it now but Im stuck here until 8
Old 03-25-2010, 12:03 PM
Pavlock Performance's Avatar
Heres our Formula. 28x10.5's
Old 03-25-2010, 12:25 PM
AChotrod's Avatar
Sexy!! What did you need to do, to make them fit?
Old 03-25-2010, 02:40 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
Depending on the actual tire you run, and rims you run, you might have to do all or any of the following:
-trim the bump stops
-hammer in the inner fender area that would up high and towards the front... let's call it 2 oclock on the passenger side, and 10 oclock on the driver's side.
-might have to deburr/hammer in front lowest sheetmeal
-hammer in/cut inner fender around the rear lower control arm mount
-might have to do a little bit of cutting of the rear bumper inside lip.
pics
325's/bogarts:
same;
same
28w bogarts:
28w bogarts
Old 03-25-2010, 03:36 PM
AChotrod's Avatar
That looks SICK!!!! Thanks for the info and pics John.
Ill try and get them on tomorrow and see where Im at. Funny thing is I had TONs of space with the 27x10.5. Hope it wont be to bad with the 28x11.5s.
Old 03-25-2010, 08:52 PM
LS1TECH Sponsor
Jon@BruteSpeed's Avatar
Take a look at my Formula on the link in my sig.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old 03-26-2010, 08:34 AM
htownws6's Avatar
I've got a boner
Old 03-26-2010, 08:03 PM
blackls1ta00's Avatar
^thats two of us dam
Old 03-26-2010, 09:17 PM
TS6
TS6's Avatar
Here's mine, same body as yours. I agree with PSJ, but with an 8" rim I doubt you'll need much clearancing. Just watch and leave some room for tire growth.
Old 03-27-2010, 10:51 AM
AChotrod's Avatar
I wish I had the cash to buy yours^^ Looks awesome!
I was a bit lazy yesterday and didnt test fit them yet. I was too busy staring at my Nitrous Outlet box of goodies that finally arrived yesterday.
Old 03-27-2010, 10:58 AM
AChotrod's Avatar
Great build!!! Thanks for the link!
Old 03-29-2010, 07:58 AM
LS1TECH Sponsor
Thanks, I took off my 28x12.5 ET Streets last yr and swapped to the radials. Going to give those a try this spring. I'm to the point where I need to start on another engine.
Yours is looking good!
__________________
Old 03-29-2010, 11:32 AM
AChotrod's Avatar
Thanks! So far its gone mid 11s @119.44 NA with way more in it, since then Ive changed out the cam added alot of suspension, changing to 28s and added a Nitrous Outlet system with all the goodies. Hope to put it in the 9s this yr.
Im just trying to see what will be involved with swapping to the 28s before I mount them on the car. So basic rule is I need about 1" all around for growing clearance on the big end?
Old 03-29-2010, 01:36 PM
kline454's Avatar
race car!!!! you need about 3/4-1 inch around for tire growth, im running 28-10.5 on a 8inch and mine rub on the bottom of the rear bumper cover on the big end but i only have about 1/2 clearance.
Quick Reply: Formulas with 28x10.5 tires pics please
