Have to start car 5+times in order for it to stay running after reflash
Old 03-24-2010, 09:16 PM
Snyper's Avatar
Default Have to start car 5+times in order for it to stay running after reflash
Every time I reflash the ecu the car starts up for a second then dies right away..I have to keep trying to start it a bunch of times then finally it starts and runs..and after that it will start every time..until I reflash..any ideas?
Old 03-24-2010, 09:22 PM
Doc
Doc's Avatar
Fuel pressure good?
Old 03-24-2010, 10:11 PM
Snyper's Avatar
perfect. as im starting it im hitting the gas..the tb is opening but the engine just dies almost like it doesnt have gas. I have the pump on a switch so its on the whole time..and it supplys 58psi perfectly....
Old 03-25-2010, 05:26 AM
poconojoe's Avatar
Are you bench reflashing it or doing it in the car? If you're doing it on the bench, you need to let the battery power hooked up after you turn off the ignion power pins.
If this is a swap are you sure, that all the battery connections on the PCM have constant power? Are you dong a complete flash or just a calibration flash? Do any DTC's come up after it doesn't start trhe first time?
Old 03-25-2010, 09:10 AM
Snyper's Avatar
Ive had the car running all last year and never had this problem. The whole car is together(wired the same) and im reflashing in the car. Sometimes it will take me 20+times to get it running...the car will fire and immediately die. Once I FINALLY get it running the car runs and stays running and I can turn the car off and restart it as many times as I want and it fires RIGHT up...until I reflash it again. Fuel pressure is a constant 58psi and my pump is run off a switch so it stays on and I know im not losing any pressure(watching the gauge)
Old 03-25-2010, 09:31 AM
Moderator
jimmyblue's Avatar
I think this is idle airflow, learnings (LTIT/STIT) get lost
after flash and it takes a while to get it back. If the
base is way off (or if something has come on, that needs
more idle air than originally) it can take a bit of time to
learn its way back.
Same thing happened to me after cam swap, until I got
the idle bedded in again.
Old 03-25-2010, 10:34 AM
Snyper's Avatar
learn its way back.
Im running complete open loop. No o2s or MAF. It almost seems like something is out of sync and I have to catch it on the right turn in order to work..
Old 03-25-2010, 10:42 AM
WeathermanShawn's Avatar
Whats your cranking VE set at?
Also, your VE Airflow at idle...If you are open-loop and not perfectly dialed in..about that the only thing that could explain it..
Old 03-25-2010, 11:11 AM
Snyper's Avatar
Stock. And what would make it do that a bunch of times then eventually just fire up and run? Once I get it to fire it and I turn it off it starts right back up again.
Old 03-25-2010, 12:07 PM
Its almost like to keeps defaulting to an inaccurate IAT and/or ECT reading.
When it finally cranks up, the PCM stores those IAT/ECT values. When you re-flash you somehow fail to store those values.
I am guessing, but that about all I can think of.
Old 03-25-2010, 12:10 PM
LS1Tech Sponsor
hellbents10's Avatar
Do have maf fail at 0?
Old 03-25-2010, 12:41 PM
Snyper's Avatar
yes maf is at 0. another thing is my vcm scanner will read codes but not of the default gauges move or work
Old 03-25-2010, 04:02 PM
Moderator
jimmyblue's Avatar
Open loop ignores LTFT, optionally STFT, but the idle
airflow short/long trims are an entirely different deal.
