Fan & Thermostat Question..
Hey guys, this is my first post. Well I purchased a 2000 Firebird Formula about a month ago it has 50k miles and runs/looks mint and is bone stock. I'm doing ALL basic maintenance first (fluids/filters) and then im moving onto cooling. I need advice on a transmission cooler... which one is best, and how big should I go? Also, I'm not sure if the thermostat is 180 or 190. Also I need to know the temp. at which my cooling fans turn on.
Stock fan settings are Fan 1 on at 226* and fan 2 on at 234*.
As for the tranny cooler, bigger is better. Go with the biggest one you can fit. I personally have a 24000 GVW derale cooler and am upgrading to a larger one with a big *** fan
Nice. thanks for the fast reply. I think I already know the tranny cooler I wanna get. I want the fans to kick in sooner than that... but I don't wanna buy an expensive programmer. Is there a switch wired to the block or something? That's how the setup was on my 87 trans am. I changed the fan switch on the block itself.... it was cheap, easy, and it worked well. Why cant I find something like that for the ls1? ohh and I think my thermostat is a 180 but I'm still not sure.
LS1Tech Administrator
Received 1,486 Likes
Fan settings can only be changed via custom tuning on these cars. That 3rd gen fan switch mod won't work here.
The stock t-stat for all LS1s is an 86°C (187°F) unit, so unless somebody changed it that's what you have.
The B&M trans coolers are my personal favorite. Very strong design, and high quality construction. That would be my recommendation. The 16k GVW unit is plenty big for a stock car, but try for the 19k or 24k if you plan on higher shift points, a big stall, and lots of horsepower.
For a stock car I wouldn't call it a requirement, but it's certainly a good idea and will extend the life of your trans.
