Difference between 98-00 and 01-02 slaves ?
Old 03-25-2010, 02:12 PM
Bad Notch's Avatar
Default Difference between 98-00 and 01-02 slaves ?
The slave in my 2000 T/A is in mint working order. I have an upgraded Tick MC coming and a new clutch from Kentucky Clutch. My question is, what is the reason for the upgrade to the 01-02 Slave? Im hoping that i can leave my current stock slave full of fluid then add the Tick performance ( bench bled ) and then only have some minor bleeding to do once I re-install everything.
I do have a NIB 01-02 slave to install but after reading all the horror stories about people bleeding out their systems out, It makes me wonder if the "upgrade" is even worth it.
Thanks
Old 03-25-2010, 03:24 PM
lazyboi808's Avatar
Yes..some slave have been known to be different in size. Only by 1/8th or so but thats alot when it comes to our picky ls1's. It can mean the difference between premiture wear or not engaging the pressure plate fully, which is my issue now I think. I suggest when you get the trans off and out.....measure the slave to the base of the trans.
https://ls1tech.com/forums/manual-tr...good-tech.html
I used this thread for some help.
Old 03-25-2010, 03:57 PM
Bad Notch's Avatar
Yeah, you are one of the guys I was reading about that was having all kinds of issues. Did you ever get everything straightened out ?
Old 03-25-2010, 04:04 PM
araber89's Avatar
Location: Holmes County (thats right Amish Country), OHIO
Get a Speed bleeder!!! They are awesome! And upgrade the slave. Its cheap insurance that you won't burn up your new clutch. And your going to love the TICK MC. The speed bleeder from Tick is easy to install and use.
Old 03-25-2010, 04:37 PM
Striker's Avatar
Does the Tick MC require a lot of cutting on the OEM pieces?
Old 03-25-2010, 05:40 PM
lazyboi808's Avatar
kinda.........just having trouble goin into 1st, reverse and it rolls slightly when i go into gear at a dead stop...so im goin to replace my clutch with monster ..there kits use oem master and no shim...tired of this ****
Old 03-25-2010, 07:51 PM
fergymoto's Avatar
In my experience, even if you bench bleed the MC the whole system still needs to be bled. There is supposed to be no bleeding required with the stock quick connects but in my experience there is always a little bit of air.
Old 03-25-2010, 08:16 PM
Bad Notch's Avatar
That sucks man. I just got a clutch from Kentucky Clutch and it uses a shim so I hope it all turns out ok.
Old 03-25-2010, 08:26 PM
Yun Gunz's Avatar
a few post belows urs at the moment from 87GN Rickie, we are going through the same thing on his car, from KY Clutch. Sadly i have one of their setups in my dads car with no issues ever, but his and urs sound the same recently, replaced his, MC, and slave, did the whole shim job and the pedal still feels spongie. Disconnected the line from teh slave to check the MC, stiff as a rock, so obviously that works. But with new shims, no leakage from the slave, we cant tell what the problem is. I know after all this im personally not going to go back to them, but his pressure plate is Spec from KY Clutch, is yours as well?
Old 03-25-2010, 11:48 PM
the_merv's Avatar
A Speed Bleeder is pretty much a requirement with the LS Cars..lol..it takes me about a minute to completely do the Hydraulics in my Car with the Speed Bleeder.
I always bleed them for that reason.
Old 03-26-2010, 01:32 AM
99huggerorangeZ's Avatar
who sells the speed bleeder?
Old 03-26-2010, 07:35 AM
the_merv's Avatar
LPP, Tick Performance..someone said Auto Zone..
Old 03-26-2010, 01:34 PM
got any links?
Old 03-26-2010, 02:08 PM
the_merv's Avatar
HERE..
Quick Reply: Difference between 98-00 and 01-02 slaves ?
