ABS fault in DIC
ABS fault in DIC
04 a4 GTO. I deleted the ABS system in the car and tring to findout how I can delete the ABS fault or trick the BCM so it doesn't trigger the fault on startup in the main display.
Do I need to run a resistor somewhere, ground or cut a wire? Any help would be great.
