Guys with ORY come in
Old 03-26-2010, 05:33 AM
JeaneGrae's Avatar
Default Guys with ORY come in
Debating whether or not to go ory or catted y from TSP. My questions for you guys runnng the ory do you get the gas smell inside your car? What about the loudness? Is it unbearable? I have a tame catback for cruising but opens up when i get on it. running the Random Technologies 3 in catback. My main concern is the gas smell because it is a daily driver and the cruiser occasionally with the family.
Old 03-26-2010, 05:41 AM
Gordon0652's Avatar
I never had the gas smell in my car. Before i threw KOOKS cats on my exhaust i had LTs, ORY, and Corsa - after installing the cats it cleaned up the sound under acceleration in a high gear.
Old 03-26-2010, 08:01 AM
Mart00SS's Avatar
This was a big concern of mine when I was deciding on an ORY or not because I had an old Carb'd firebird with duals and no cats and man did the inside of that car smell. Surprisingly with this car and an ORY it doesnt smell. Every now and then if I have the windows down I catch a small wiff but not often. i have it going through a stock catback so its definitely not too loud.
Old 03-26-2010, 08:08 AM
bongva's Avatar
i have pacesetters ory and LT's, and every once in a while it smells, but thats because im just using cheap clamps, and the sound is not that loud at all. my car is dumped at the rear end, and i think its rather quiet.
Old 03-26-2010, 09:40 AM
DaveX's Avatar
Mine stinks bad, but rarely smell it inside the car. If you have the factory cam it shouldn't be bad.
Old 03-26-2010, 10:00 AM
Super Speed's Avatar
Smells good man!
Old 03-26-2010, 10:04 AM
Sy99T/A's Avatar
Hooker L/T, with custom bent all the way out the back into thrush mufflers that dont quiet the sound any, no cats and a 228R cam. Excessively loud but no smell
Old 03-26-2010, 12:29 PM
heartless_T/A99's Avatar
ARH LT's and ory with magnaflow catback. Quiet while cruising but opens up at WOT and no gas smell here.
Old 03-26-2010, 01:46 PM
VeTTeMaNC486's Avatar
I love the way my cars smell w/o cats.
But no I dont smell any of them inside the car, its pretty intense if you stand behind them however.
Rasp on the other hand. O M G. So effing bad with the LM1 I have. It sounds ******* horrible. Temped to put a dump on the end of the Y or something because its loud AND sounds like **** with the LM1, couldnt sound any worse with just a turn down hahaha.
Old 03-26-2010, 01:53 PM
Titanws6's Avatar
Yeah, the rasp will be more annoying than the gas smell, if you go ORY, I would have a Flowmaster Merge installed to eliminate the rasp. If you go with a catted Y, you shouldn't have any rasp problems. Or, you can put a bullet in the I-pipe and that will help eliminate rasp too.
I had bad gas smell with my ORY, but my tune was outta whack. With the new tune, hardly any gas smell.
Old 03-26-2010, 03:51 PM
brian_rs/ss's Avatar
yeah i have the TSP o/r y and rumbler cat back on my car and i hate it. but screw cats, i have a 4" flowmaster merge and 4" mufflex cat back on the way as i type this. after talking to the people who actually have this set up, it's the only why to fly
Old 03-26-2010, 04:58 PM
conan's Avatar
Kook's LT's, and ORY, Never smell fumes in the car. Now if its running inside or you stand right behind the car it will make your eyes burn, I do like smell though.
Old 03-26-2010, 05:07 PM
Sicko's Avatar
If you run it out the back you shouldnt get the "smell", its us dumped guys that get the smell.
Old 03-26-2010, 10:00 PM
Pontiacerator
RevGTO's Avatar
First time I tried ORY smell was a factor and it would be insanely bad to be the guy behind me at a stoplight running A/C. I had GMMG and then Hooker Aerochamber and had loudness and rasp - esp. w/GMMG - along with the smell.
After running a catted Y for a couple of years, I had a new 3" into 3.5" ORY built with FM merge. With a 22" Hooker Maxflow muffler, it's not loud at all and no rasp. Tuning has helped with the smell, but it's still there.
The point: with a good merge and the right muffer, sound can be controlled. You'll always have some smell, but it can be kept below the obnoxious level - for you, at least, if not the car behind you.
Old 03-26-2010, 10:15 PM
JeaneGrae's Avatar
Default Merge
When you guys say merge, does this apply to a single 3 in catback? I didnt plan on true duals. How would this apply?
Old 03-26-2010, 10:35 PM
Detoxx03's Avatar
I run a ORY and have no such issues
Old 03-27-2010, 03:06 AM
its the "merge" of the two pipes coming off of the headers and joins them together. the flowmaster merge is a much better design than most aftermarket y-pipes. also it allows you to step up the diameter of your i-pipe and cat back. ie say you want to go to a full 3.5" or a 4" cat back.
read:
https://ls1tech.com/forums/generatio...er-y-pipe.html
Old 03-27-2010, 04:04 AM
Soul TKR's Avatar
I get the fuel smell pretty bad a lot of the time... always when stopped at a light or whatever. I recommend going cats, then just add some electric cutouts so you have the best of both worlds. I don't think the sound is an issue... As long as you have a decent muffler on it.
Old 03-27-2010, 09:32 AM
92SilverSHO's Avatar
my wife starts complaining all the time about the smell, however thats because windows are down and im idling for long periods of time in traffic in the summer, etc.
My setup is stock quiet with the cutout closed and loud with the cutout open.
Old 03-27-2010, 01:34 PM
f-body_racer99's Avatar
I got a tsp ory and tsp rumblers and it smells bad outside of the car and once and awhile inside I still have the crappy clamps it came with. is that why it leaks a crap load of gas?
