Why 8 inches???
Old 03-26-2010, 03:00 PM
FireBirdSoldier's Avatar
Default Why 8 inches???
My local mechanic (ase/master tech) shwoed me my cats are bad ok...well he says i cant have any cats over an overall length of 8 inches. And i cant find a universal to fit. And well i didnt wanna spend a ton of money since i was considering getting LT headers and stuff within a year. And well if i spend freakin 400-600 dollars for direct fits id rather get headers and a set of y pipe catted for around the same price. So does this whole cat thing sound right? And i was also wondering if LT's will scrape real bad? Stock car height (no plans to lower) is my DD. Dont wanna bust up mah headers. So whats your guys opinions? I prefer lts over other lengths but if i have to i have to. So please let me know as soon as possible. Thanks in advance for your input.
Old 03-26-2010, 04:15 PM
mcalus's Avatar
If you are staying stock height which after getting the mod bug you will lower it imo .... You will have no problems with LT's and ground clearance, buy any LT other than SLP since they have the worst ground clearance. As for the cats I would just try to get a used stock y pipe from someone on here and rock that out until you go with LT's and ory.... if thats what you chose to do.
Hope that helps.
btw why 8 inches? because thats what she said
Old 03-26-2010, 06:06 PM
Hope that helps.
lmao. And thanks.
Old 03-26-2010, 10:47 PM
PontiacFan's Avatar
You need to find a better mechanic, ...
There's a GM service letter out there that says they'll replace them for free.
Search it out, ...
Old 03-27-2010, 03:35 PM
MASS seller approved
smok'nZ's Avatar
ill sell you 1 mine with 79k for 50 shipped
Old 03-28-2010, 02:38 PM
Zaxz28's Avatar
I had mine replaced with the warranty but it is 10 year or 100k, you are coming close.....I would do the research.
Old 03-29-2010, 02:40 PM
oange ss's Avatar
you need a new mechanic....Federal regulations stipulated 8yr/80K mile warranty for cat converters..GM extended this warranty in 2006 for 00-02 F-cars to 10/120k miles
TSB #05513: Special Coverage Adjustment
