front runners
front runners
would it be worth it for me to get a set, and which ones should i get(size) looks really dont mean anything they will be track only rims i will be running stock rears with dr's(m/t). which brand requires the least amount of grinding. im looking to get some cheaper ones right now cause i still have to by street tire for my other rims.
I had a pair of of 15x3.5 Weld Draglites with Moroso Drag Specials (pretty much the lightest tire you can get) mounted on them; each combo weighed 20 lbs total, just under half what my full size fronts weighed. Last October I ran the 1/4 with the full size fronts and went 13.190 @ 106.93, 2.029 60 ft. I then swapped the Draglites on and ran again, 13.074 @ 107.44, 2.022 60 ft. Most of the small ET drop seemed to be attributable to an approximately 500 ft drop in the density altitude. They really didn't make the car much faster at all. I did like being able to roll through the water box without slinging water everywhere with the full size treaded fronts.
The Draglites fit with no grinding and a 5/16" spacer. I did put on ARP 2.5" wheel studs for safety. I recently sold them, but I just bought a pair of 15x8 Prostars and I plan on getting the matching 15x3.5 fronts (I already have the lugs, spacer and studs so why not).
Ive got a set of Greg Weld Racelites, 15x3.5's and no spacer/no grinding. 26x7.5 Sportsmans and coulda/woulda/shoulda got a set of 27.5's.......... they're going up for sale this week........
thanks for the input guys raers im not worried about im sticking with stock 16's and mickey's its the front im worried about i hate drivin around the water box and i think with skinnys i may be able to lift a wheel which would be a great pic for me.
Running a car with diminished braking and vehicle control because of inferior front tires that gain you 1/10 doesn't sound like a good idea to me!
Al
Alot of people make claims that are not true. According to some on this board, I should have picked up 2mph by swapping from the pacesetter 1 3/4 to the stepped Kooks I have now - a couple individuals said otherwise and they were right.
But with that said, every little bit adds up. If front runners weren't worth it, you would probably see the pros all running wide tires. If you're on a budget, spend the money where it will benefit you the most. If you're making the power but not getting the weight transfer you need - then skinnies are def worth looking into. If you're running a bolt on street car then don't expect much.
Check these summit stars out. They are affordable and once you see them ,the finish is really nice . Since I have WS6Store.com slotted and drilled rotors on mine , I used a 7/32 spacer on the front and the rear . Plenty of bite for my lugs and they look pretty good on my car too.
http://www.summitracing.com/parts/SUM-521-5461PS/
cheapest direct fit wheel (no grinding needed) for a stock brake setup fbody is going to the be the racestar industries dragstar
www.racestarindustries.com
BTW I just bought Prostar front runners with heavy M/T Sportsman tires on them, really more for the big/little look and for driving through the water box than for any kind of performance benefit.
My firsthand real-world experience posted above is not the only time I've done back-to-back (as in same day, same track, minutes apart) runs with the different wheel-tire combos and found very little difference once the DA has been taken into account. And my 20 lb per side (10 lb wheel, 10 lb tire) front drag combo is about as light as it gets. The rears wouldn't save much weight, the wheels would be about 7 lbs lighter (15x8 Prostar vs 16x8 stock snowflake) and the tires would probably weigh about the same. Maybe it makes more of a difference for cars that normally run heavier 17" or 18" wheels.
But from the guys I know locally who all run from mid 11's on up who have run skinnys seem to agree with you.
Not really worth it from a money spent for gains point of view.
