DDM Tuning
DDM Tuning
i am going to be installing 9006/880 hid's(lowbeam and fog) and i am going to be adding a relay harness also. has anyone else installed one? and i need 2 correct? 1 for the lows and 1 for the fogs,right?
itll come with instructions. however i didnt read them lol. its pretty self explanitory. be forewarned though, the plugs that go into the factory wiring will need to be flipped. for some reason GM pinned their connectors differently than other car companies. not a huge deal at all though. if you have any questions just give me a holler through PM and ill help you out
im going to order these tonight because of there sale price if. 9006 35w just for lowbeams correct? would you need a relay harness just for low beams if you have an optima battery?
You could (they are projector housings, also really low to the ground) but I would be concerned about the amount of heat in those little housings. You'd need a relay harness for sure with those however, the stock wiring won't handle them.
I've been toying with the idea of HID fogs, but just haven't made up my mind yet. Probably would get 35W 3000k, I suppose.
Alright just ordered up the ddm 3k 880kit with a harness. I did some searches on it. Do i reverse the polarity of the stock plugs like the headlight plugs? Saw something mentioned about painting the inside of the foglight if its cracking/peeling? how would you go about that? Does it come apart in pieces?
