LS4 Performance - Just finished putting in my DP with the cutout
havelegs
03-26-2010, 11:03 PM
Took about 2 hours or so, I was going slow and working with a flashlight lol. Install is easy, wired the the cutout to one of the 12v ports in the console. Opened up fully it sounds like a fucking race car lol. I had some kids driving one of those new VW turbo cars compliment me and they said it scared the shit out of them when I flew past them.
Here are some pics so you can see the differences between stock and the holgan.
This is the factory one, notice the reduction.
http://farm5.static.flickr.com/4038/4466430088_b396cee3a4_b.jpg
Hogan, notice no reduction and smooth.
http://farm5.static.flickr.com/4041/4466431020_1a272366d6_b.jpg
Side by side, notice the huge cat, this also weighs about 15lbs or so less than the factory one.
http://farm3.static.flickr.com/2695/4465656379_523b8d47ea_b.jpg
I need to recheck the wiring tomorrow and make sure the bolts are all tight. I highly recommend it and you do feel a difference in power with the cutout open.
DieselPump
03-26-2010, 11:22 PM
very nice, I'll be installing my hogan dp tomorrow, looking forward to it!
Z28 Autobot
03-27-2010, 08:00 AM
Welcome to the cutout club! And we do have a topic posted for anyone that has one installed. Post pics and if you have vid of it.
Vectus
03-27-2010, 08:45 AM
I been meaning to do this... I had some guy reving his car at me yesterday... I opened it up and reved back... the look on his face? Priceless...
OP looks good man! Let's get some sound clips...
TheMonteMan
03-27-2010, 12:05 PM
do the catted dps throw a code?
havelegs
03-27-2010, 12:15 PM
No, no codes. This is a "high flow" cat, but I guess it is catless?
CenTexSS
03-27-2010, 12:20 PM
A lot of people with the catted DP get a p0420 code. I used an 02 spacer/extender and it prolonged the light for about 1000 miles or so.
DieselPump
03-27-2010, 02:42 PM
what size are the bolts that attach the dp to the manifold and cat to the rest of the exhaust?
Just want to make sure I have things in order.
Thanks
rquinn19
03-27-2010, 02:45 PM
Catless would mean no cat at all. A high flow cat is still a cat. I have no experience with these cars, but with others with high flow cats a spacer helps keep the readings at the rear 02 sensor down so it won't throw a code.
havelegs
03-27-2010, 03:34 PM
Thanks
15MM, you'll need a deep socket with a 12inch extension. They are on tight so either use a lot of man power or maybe go to a shop if you can't loosen it and ask if they can break them loose for you. I didn't spray mine with any oil because I live in a rust free zone, FL, but you might want to spray it with some penetration oil.
havelegs
03-27-2010, 03:35 PM
Also you'll need either an O2 socket or a 22mm wrench to get the O2 out. I left the O2 in until the pipe was removed and then used a wrench to take the O2 out.
havelegs
Do you have the link to that thread?
CenTexSS
03-27-2010, 04:45 PM
Also, do not use a 12 point socket for the 15mm bolts, be sure to use a 6 point to advoid rounding the bolts.
havelegs
03-27-2010, 05:16 PM
Just made this vid. At the start of the vid the cutout is closed, then you can hear it open.
http://www.youtube.com/watch?v=7Qeoa8kRJRU
CenTexSS
03-27-2010, 05:38 PM
Sounds good. Now take her to the track and see what she does!
DieselPump
03-27-2010, 05:48 PM
Thanks a lot havelegs and centexss for the info, much appreciated
