Carburated LQ9 guys? Got some questions
Old 03-27-2010, 02:53 PM
Palomba's Avatar
Default Carburated LQ9 guys? Got some questions
Ok so i need the intake manifold, carburetor, and MSD box.
Will the stock LQ9 cam run good on a carburated application?
What fuel pump are you guys using? And how did you convert it to work with your stock tank if you were previously fuel injected?
Old 03-27-2010, 09:08 PM
Dickie-311's Avatar
i have a edlebrock victor JR intake , MSD 6010 BOX
DEFFENTLY a good idea to swap out the cam and valve springs ,
i'm using a Aeromotive A1000 fuel pump and going to sump my tank
Old 03-28-2010, 12:13 AM
Palomba's Avatar
i may use my stock fuel pump with a good regulator on it.
As far as the cam goes, its a no go with carb huh?
Old 03-28-2010, 12:23 AM
garys 68's Avatar
I ended up going with fuel injection on my LQ9, but was looking into a carb setup first.
The LQ9, 6.0L runs the same cam as the LS1 5.7. Fine for a daily driver but the carb intake and heads can flow A LOT more than that cam can support.
If you're interested in lots mor hp in the 5000+ rpm range a simple cam/spring swap and headers add a lot.
Good article here.
http://www.carcraft.com/projectbuild...ock/index.html
Quick Reply: Carburated LQ9 guys? Got some questions
