Need help: Water and oil adapters for LS3 gauges
Old 03-27-2010, 11:43 PM
SickF85's Avatar
Default Need help: Water and oil adapters for LS3 gauges
Guys,
Just got the LS3 into my '68 Cutlass. I've looked around on here through the stickies, but need some help on where to buy adapters for my water temp and oil pressure gauges. I'm not sure if my mechanical gauges will work or if I need to switch over to electric.
I need fitting size for water and oil and where to buy.
Thanks.
Pics coming shortly.
Old 03-28-2010, 08:55 AM
Jimbo1367's Avatar
These are listed at www.Paceperformance.com This is from the " Engines sensors and Switches"
Engine Conlant Temperature sensor adapter
http://paceperformance.com/index.asp...&ProdID=105932
Oil pressure adapter
http://paceperformance.com/index.asp...D&ProdID=88869
Hope this helps some.
Jim
Old 03-28-2010, 08:58 AM
Jimbo1367's Avatar
This part number can be used at http://www.summitracing.com/ & http://www.jegs.com/Specials
Old 03-28-2010, 09:00 AM
Jimbo1367's Avatar
http://www.summitracing.com/parts/ATM-2268/
http://www.summitracing.com/parts/ATM-2277/
Old 03-28-2010, 01:29 PM
SickF85's Avatar
Guys, Many thanks!
Quick Reply: Need help: Water and oil adapters for LS3 gauges
