BMR K member alignment
Old 03-28-2010, 11:48 AM
koji777's Avatar
Default BMR K member alignment
I've got the high clearance BMR Kmember and upper/lower A-arms installed on my car. The front wheels are "forward"in the wheel well, not centered. The K-member has 2 pins that locate the K-member on the frame, nver checked to see if there was any room to move the K-member backwards.
Question.. is there any slack or adjustment that I am supposed to do to get her to sit back about 2" so that the wheel is centered?
Thanx in advance
Old 03-29-2010, 07:01 AM
BassProCamaro97's Avatar
Are the A arms adjustable?
If not then the K-member may be off, or installed incorrectly.
~Jim~
Quick Reply: BMR K member alignment
