Strange vibration.
Strange vibration.
Well, not that strange. But when I sit at idle the whole car shakes. My tuner put the idle up to 900 and it runs fine. But its like its missing or something. Not sure what it could be. I've replaced plugs with AC Delco Iridiums, MSD plug wires, and I'm assuming all coils are ok. Not too sure on the last one. When I rev it up to 1300 it smooths out but I can still feel it missing occassionally. Any help would be great cause this is driving me insane. It was doing this before the cam swap also. So, I don't think that is the problem. My tuner said I needed new motor mounts, but I still think It should be running smoother. Thanks!!!
i had that with my 01 z28 i had to replace the #8 injector... is it triping the service eng light and if it is have the code read cuz if its a miss then the reader will tell u its a miss and witch hole is missin... good luck
Not throwing any codes. It runs fine but feels almost like it runs fine then it just forgets to fire one of the spark plugs. It keeps doing that. Like its missing. I can't really put my finger on it or describe it.
Yeah my car is now doing the samething and the computer said it was a #4 injector fault so I had it replaced and its doing the samething... Dont know where else to look I've replaced everything else....
Yeah, I'm still having the same problem myself. I don't know what to replace. I'm not getting any misfire codes. Do coils slowly go out? Or is it either there or not?
