LS1 in a 55 chevy truck; speedo ???
Old 03-28-2010, 03:53 PM
Mike Cordero's Avatar
Default LS1 in a 55 chevy truck; speedo ???
I will be using a LS1 automatic car in a 55 chevy truck with an old Camaro rear end too. I'm planning to use an aftermarket speedometer (Dolphin or auto meter) and I want to know if it should be machanical or electrical and from where I will take the reading for the speedo? Thanks.
Old 03-28-2010, 06:33 PM
TomM's Avatar
Get an electric speedo........
It will use the wire from the PCM to the speedo signal input...
T,
Old 03-28-2010, 07:12 PM
T,
Thanks man, any brand suggestion? I would like the old look with the new performance. The Dolphin speedo, they said that can be programmed to any combo of wheel and rear end ratios.
Old 03-28-2010, 09:36 PM
TTLS1GP's Avatar
Look up JML55 on the boards. He used a dolphin set in his 55 5.3/4l60E combo. He may be able to provide you some insight.
Old 03-28-2010, 10:04 PM
fptransport's Avatar
I just finish hooking up a electric speedo in my swap and I can tell you is dead on the spot, I when for a drive with the wife setting the 08 suburban cruise contrlo and the auto meter was right there....
also was easy to hook up,,
Old 03-29-2010, 07:44 AM
TomM's Avatar
Autometer makes some gauges called the Old Tyme series, I put them in my Nova, have an old school nostalgic look...check them out...mine is also spot on, against two other cars and my GPS....easy to set up and calibrate....
T,
Old 03-29-2010, 08:25 AM
MeanYellowZ's Avatar
+1 for the Autometer electronic speedo's. Much better quality than the Dolphin gauges. I have installed both in customer cars, you get what you pay for.
Old 03-31-2010, 05:42 PM
First, thanks for your words. I read in the Classic trucks mag, that the Dolphin electric speedo is programmable for any wheel size and rear end ratios. Do the autometer one can be programmed too or how it work?
Old 03-31-2010, 05:43 PM
How I can contact him?
Old 03-31-2010, 06:55 PM
Jimbo1367's Avatar
Default elertic speedo
I read somewhere........ that the new electric speedometer ( unfortionatly I don't recall the brand or model) only required you to drive a measured mile and rest it. then you are done. I wish I could of remember more of it though.
Old 03-31-2010, 08:25 PM
theomms's Avatar
How to you think Classic Instruments gauges compare to Autometer?
Classic Instruments
Old 04-01-2010, 12:35 PM
TTLS1GP's Avatar
you can search for him and then PM
Old 04-01-2010, 05:40 PM
sawzall wielding director
G-Body's Avatar
Watch out for the old tyme series if it has the mechanical odometer......that mecahnical odometer SUX!!!!! it randomly decides to stop logging miles....and then start back up for no apparent reason.
Old 04-01-2010, 05:59 PM
TomM's Avatar
Noted........Mine are all electronic....cheaper than a cable x box by a long shot.....
T,
Old 04-01-2010, 06:03 PM
46Coupe's Avatar
Classic Instruments. Great for streetrods.
Quick Reply: LS1 in a 55 chevy truck; speedo ???
