Raptor Shift Light question
Old 03-28-2010, 04:58 PM
MattHatt89's Avatar
Default Raptor Shift Light question
I have the one with the Launch mode and what im not understanding is it says connect the green wire to the tach output lead of the vehicle or the switched side of the ignition coil, the negative side. Not exactly sure what that means??? anybody whos used this shift light please chime in.
Old 03-28-2010, 06:30 PM
bayer-z28's Avatar
Look for the tach lead on the ECM. I T'd mine into that.
Pin 10, White wire, IIRC.. Or the negative lead of Coil #1, but I just used the ECU Tach lead. and the light has to be in 4Cyl mode to work properly.
Old 03-28-2010, 11:53 PM
MattHatt89's Avatar
How do you get it 4cyl mode? does the x1000 side need to be on 0 while the x100 is on 4? i got the light on and working but no signal from it.
Quick Reply: Raptor Shift Light question
