Vengeance Racing introduces Magnum T56 DIRECT Bolt in for F Body!!!
Old 03-29-2010, 09:29 AM
Ron@Vengeance's Avatar
Default Vengeance Racing introduces Magnum T56 DIRECT Bolt in for F Body!!!
Vengeance Racing is proud to bring you the strongest T56 available!!! Built by RPM Transmissions this Magnum T56 includes the following:
  • 26 spline input
  • 31 spline output
  • Bronze fork pads
  • Bronze shifter bushing
  • Fully Micropolished
  • Custom machining of internal components to fit the F-body tail
  • Modification of Tail housing to fit the magnum
This transmission is a DIRECT bolt in for your 4th Generation F Body AND Pontiac GTOs!! To be converted, the transmission has to be disassembled completely to modify the mainshaft, clutster shaft, and other parts, as well as the tailhousing being modified to fit the larger shaft and one piece cluster. The shifter rail is a custom built piece as well to fit the magnum transmission with the F-body tailhousing. We also install a custom reluctor ring for the F-body
$4995.00 RETAIL
$4495.00 without Micropolish/Bronze Pads
$1695.00 To modify your Magnum
**Faceplating is Available!!!**
$3500.00 1rst thru 4th
Additional $1200.00 for 5th/6th
No core!! Pricing is OUTRIGHT!!
Feel free to give us a call with any questions you might have or to place an order!!!
Old 03-29-2010, 09:36 AM
Big_Bird_WS6's Avatar
so this is a magnum. you just put a stock t56 tail housing on it?
correct?
Old 03-29-2010, 09:39 AM
also how much for just the modifed rear housing?
thanks
D
Old 03-29-2010, 09:40 AM
how much for the rear housing part?
or can i send you a rear tail shaft part and have you modify it to fit my magnum?
thanks
D
Old 03-29-2010, 10:01 AM
jerflash's Avatar
I may like to get myself one of these...lets see some prices thanks!
Old 03-29-2010, 10:22 AM
thesource's Avatar
Good looking unit but thats got to run about $3500 to build it like that. A new Magnum is $2800 by iteself.
Old 03-29-2010, 10:23 AM
There are modifications required to the transmission itself that would not allow us to sell you just the tail housing.
That being said you can send your transmission in for complete modification. We are working on pricing for this option as well.
Old 03-29-2010, 10:47 AM
well figure up a price for me.
i have the t56 tail housing and the magnum ready to go out the do.
can i ask is it just making the rear housing biger to take the 31 spline set up. kind of like what guys do in the viper conversions?
thanks
D
Old 03-29-2010, 11:23 AM
thesource's Avatar
thanks
D
I would imagine its more than just boring out the tailhousing for the larger bushing and seal. I would "think" the shift rail is different, the shift selector in the back is different, the rear cluster bearing is different and the VSS needs to be addressed. I have not been into a Magnum yet so its just a guess at this point. The bronze fork pads and shift cup are from a T56.
Old 03-29-2010, 11:35 AM
well i figured there was more involved. but had to ask. lol
Old 03-29-2010, 01:23 PM
Working on pricing guys!!! Will post up ASAP!!!
Old 03-29-2010, 05:45 PM
well sounds good Ron
let me know when you get a price. then i can get this stuff sent to you.
thanks
D
Old 03-29-2010, 07:52 PM
Sprayed 99's Avatar
in the market for a strong *** trans, i'm interested
Old 03-29-2010, 11:51 PM
SHovV's Avatar
i would be interested in one of these. i luuuuuuuuuuuuub my 6spd!!
Old 03-30-2010, 03:10 AM
DVS99TRANS's Avatar
Curious on this also, I am looking to get my t56 reworked when I hit North Carolina again hopefully a little over a year...
Old 03-30-2010, 03:27 AM
same o'j's Avatar
what about the gears ratio !
its same stock or diffrenet?
thanks
Old 03-30-2010, 03:51 AM
Soul TKR's Avatar
so what's this "magnum"?
I'm sort of transmission illiterate so... what's the difference between it and a built T56 Tranny?
Old 03-30-2010, 08:22 AM
Kleeborp the Moderator™
MeentSS02's Avatar
It's the Tremec TR-6060 - from what I've gathered, it is the replacement for the T-56, and is a little beefier.
Old 03-30-2010, 08:50 AM
SHovV's Avatar
what is the HP/TQ will this swap handle?
Old 03-30-2010, 08:59 AM
SMOKNSS's Avatar
Hey this pretty cool Ron. Subscribed.
Quick Reply: Vengeance Racing introduces Magnum T56 DIRECT Bolt in for F Body!!!
