Just order a set of these
http://www.summitracing.com/parts/BM...ry=Year%7c2002
It was a last minute purchase which I needed to be here in two days.
Did I do ok?
Does anyone have experiance with these?
Did I do ok?
they aren't that bad but the polyurethane won't let the suspension articulate the way it should since that material isn't very forgiving... polyurethane is ok for mounts and sway bar endlinks but for parts that need to move in all directions such as your lcas and phb then i would get rod ends or rotojoints... for just a little more you could have bought some umi double adjustables with rotojoints on both ends, that's the way to go imo... i love umi's stuff and their rotojoints are awesome, they make no noticeable noise over the old worn out stock stuff that was on my car
it causes bind in the suspension... basically it wants to move but the bushing resists the movement... i have never personally seen this but i have heard of people bending the mounting brackets for their phb/lcas when using poly ended parts under aggressive driving
If by track you mean drag strip, they will be fine. I daily drove with poly/poly lca's and they worked fine for straight line stuff, but when I started autoxing I ditched them.
