383 Build
A good rotating assembly will run you in the neighborhood of $2000-2500 depending on the parts used. You will also have a couple hundred in block work to hone the cylinders and clearance the block, etc. From there it would be assembly. Here's a link to some rotating assembly options.
http://www.texas-speed.com/shop/item...d=884&catid=88
Jon
Jon
