Intake Question
Old 03-30-2010, 06:06 AM
Z28-Z71mAn's Avatar
Default Intake Question
When swapping to the ls6 intake instead of doing the coolant crossover pipe you can just chizzle off the plastic ribs underneath. But... if I were to do the fast 92 intake would I have to use the ls6 crossover pipe? Or can I chizzle the plastic ribs? Or is it even possible to just use the ls1 crossover piping on there? Thanks for any input.
Old 03-30-2010, 12:19 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I cut the ribs off my LS6 intake and reused the LS1 coolant lines when I put it on my '00.
Can't help ya on the FAST cause when I put a 90mm FAST on my CETA GM done the coolant lines for me since it is an '02
Old 03-30-2010, 05:28 PM
garygnu's Avatar
I used the stock ls1 coolant lines with a fast 92 intake. use a piece of wood and a plastic hammer to carefully bend it down a little bit.
Old 03-31-2010, 06:13 AM
Z28-Z71mAn's Avatar
when you hammered it down, did you just bend it straight down or move it at a certain angle? Or will I be able to tell what to do with it once I get the intake on? Thanks
Old 04-01-2010, 12:53 PM
Z28/2002's Avatar
I hammered mine down until it was sitting on the valley cover and then tapped the corner that was hanging off the back of the valley cover down a little more
Old 04-01-2010, 05:24 PM
garygnu's Avatar
just tap on it till it is under 1/2".start in the middle and work your way out.you don't need any sharp angles at the corners.
Old 04-01-2010, 10:51 PM
Z28-Z71mAn's Avatar
Thanks for the input Z28/2002, garygnu. I wanted to ask some questions before I tackled this job. Im kinda nervous bout takin a hammer and block to the coolant lines, but ill just be extra careful. You guys wouldnt happen to have a picture availble so i can get a better idea on how it looks? Thanks
Old 04-03-2010, 01:06 PM
Z28/2002's Avatar
I'll have to look on my laptop. I know I have a pic of my LS1 and LS6 intake side by side and also one with the ribs off the LS6. I don't know if there is one of the coolant lines though. I'll post back whenever I get my laptop out and look
Old 04-04-2010, 08:04 PM
Z28/2002's Avatar
Here is a pic of my LS6 intake when I took all the ribs off it
Old 04-04-2010, 08:38 PM
David Q's Avatar
Chip off the ribs and file it smooth if you can. The factory coolant lines will fit. I used a 40 grit tiger disc on a 4 1/2" grinder and it cleaned up real well.
Old 04-04-2010, 08:43 PM
colt_impala's Avatar
i chipped the ridges in mine bc i heard rumors that changing the coolant pipes wouldnt keep one of the cylinders cool. (cylinder 7 i think)
Old 04-04-2010, 09:39 PM
SweetS10V8's Avatar
If this was true GM wouldnt have changed EVERY LS engine to front only crossover and block offs in the rear, like the LS6.
