Gears & Axles - Average Shop charge install complete Axle Assembly
texas99Z28
03-30-2010, 08:14 PM
How much on average, does a typical shop charge for an install of a Strange 12 Bolt for example? To buy one seems to be around $2400.00. Do they come to the shop complete, ready to bolt in? Including Ring and Pinion, axle bearings already pressed on axles, etc.?
texas99Z28
04-01-2010, 06:36 PM
bumpp
TurdsOfMayhem
04-03-2010, 06:05 PM
any1 able to help him?
00ssmg
04-04-2010, 11:30 AM
strang 12 bolts come completely assembled. you would just be changing the whole unit. i would assume a shop is going to charge you a couple hundred. you should do this your self it isnt hard.
conde'strans
04-06-2010, 12:21 PM
It comes completely assembled only if you send them the brake plates from your stock 10 bolt or if you tell them to install their own which costs like an extra $300 if i remember correctly! If not i guess they can send it to u without them n then u would have to pull the axles n press everything that goes on the axle yourself.
