Convertible Vehicles - Bolt in subframe connectors?
95_transam_lt1
03-30-2010, 10:47 PM
Are there an true bolt in subframe connectors? I want to put a set on my 95 vert but dont want to weld anything because of its low miles
voudoo
04-01-2010, 10:51 PM
UMI makes a nice kit
HERWS6VERT
04-03-2010, 10:12 AM
We just put a set on my car from UMI. They fit perfectly, and are simple to install. Took longer to get the car on jackstands than it took bolt them up.
UMI Performance
04-03-2010, 11:13 AM
Thanks for the compliments everyone :)
Like mentioned our set-up is 100% bolt in, they require no cutting, grinding or drilling. They use existing holes already in the chassis and we supply you with all the hardware needed.
Here is the bolt on set-up- www.umiperformance.com/2027
If you have any questions please ask. Thanks!
Ryan
red87iroc
04-19-2010, 12:20 PM
Correct me if I am wrong, but it looks like these bolt-in connectors could be welded in at a later date if desired, correct?
voudoo
04-21-2010, 04:54 PM
yes. also my understanding
libertyforall1776
05-21-2010, 12:15 AM
No, if you're going to do that, go with the 2026 with bolt-in hardware, and weld-in later -- you get more weld points!
Much better to weld in the first place, that's what I'm doing on both my SS & RS...
UMI Performance
05-21-2010, 11:48 AM
All of our bolt in SFC's can be welded at a later date.
Like mentioned if you plan on welding them then we recommend these with the bolt in hardware option- www.umiperformance.com/2026
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
