General Maintenance & Repairs - Crazy electrical problem!! Help asap
AFASTYZFR1
04-01-2010, 11:37 AM
Car is having crazy electrical problems....all light bulbs work but shit is acting crazy....any ideas?
With motor off:
http://i210.photobucket.com/albums/bb201/D-1SC_SOM_SS/th_MVI_4142.jpg (http://s210.photobucket.com/albums/bb201/D-1SC_SOM_SS/?action=view¤t=MVI_4142.flv)
With motor on:
http://i210.photobucket.com/albums/bb201/D-1SC_SOM_SS/th_MVI_4143.jpg (http://s210.photobucket.com/albums/bb201/D-1SC_SOM_SS/?action=view¤t=MVI_4143.flv)
AFASTYZFR1
04-01-2010, 12:25 PM
I have disconnected all lights on the front of car and swapped them around and this is what happens still......WTF
http://i210.photobucket.com/albums/bb201/D-1SC_SOM_SS/th_MVI_4144.jpg (http://s210.photobucket.com/albums/bb201/D-1SC_SOM_SS/?action=view¤t=MVI_4144.flv)
BOA279
04-01-2010, 01:41 PM
you most definitely have shorted wiring. The left turn signal is lighting on the dash because of stray voltage from the low headlight wiring. This draw also causes the headlight to dim as two bulds are being powered from the same source. Well, you could say 3 because of the dash light. The turn signal and headlights are completely independent circuits so the only explanation is they are shorted together. Were those halo's spliced correctly? also fish around and find their grounds as they may be common. This should be really easy to find...take out that headlight assy and check all the wiring. Something could have pinched the wires or cut into them.
AFASTYZFR1
04-01-2010, 05:24 PM
turns out the battery was just low.....took car out and drove around for 20 min and now everything is back to normal
AFASTYZFR1
04-10-2010, 08:08 AM
WTF! Put a new battery in it and it was fine for awhile with no issues.....But last night it did it again :confused:
fleetmgr
04-10-2010, 09:53 AM
What state was the battery in when it did it again? Was it low again? If so, then something (like a short) was causing it to be low.
AFASTYZFR1
04-10-2010, 10:04 AM
brand new red top.....going to start looking over it soon :bang:
Firebirdgm2000
04-10-2010, 10:42 AM
check alternator.... also check the grounds on the frame maybe pull each fuse one by one in the drivers compartment for testing
SparkyJJO
04-10-2010, 11:16 AM
What happens when you turn parking lights on, but not the headlights?
Turning the fog lights off make any difference?
How about headlights on, turn high beams on?
AFASTYZFR1
04-10-2010, 01:16 PM
So my buddy who owns the car found out battery terminal was a little loose....I cleaned terminals and tightened them down as much as possible without stripping them...car works fine now :bang:
will have to wait and see if that fixes it for good :hail:
whiteboycntdnce
04-11-2010, 09:23 PM
So far so good! One thing that wasn't mentioned, the last time the system went crazy I noticed (just before it all started) that my voltage was rather high (around 15-16) First the ABS/INOP light, then the turn signal indicator, followed by the meth kit turning itself on at idle ... A few miles down the road the issue seemed to correct itself.
It wasn't untill the following morning that I popped the hood and found the cable to be kind of loose. I have put about 60 or so miles on the car since both terminals were cleaned and tightened and no issues! I have been told it may be a good idea to use a longer bolt on the cables since optimas seem to have an extra "lip" or platform that restricts the amount of threads that are usable. I dunno, keeping my fingers crossed!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
