I need help !!!lq4 conversion
Old 04-03-2010, 10:04 PM
SmokeU's Avatar
Default I need help !!!lq4 conversion
Swapped an lq4 into my 2000 ss,everything went smooth but as soon as i went to start it no spark. It wants to start but wont.
I have both pcms lq4 and ls1 and it wont start. I was told it was the reluctor gear, crank or cam sensor help!!!!!!!!
Thanks,rick
Old 04-03-2010, 10:38 PM
Pocket's Avatar
A bad crank sensor will cause a no start situation. Do a few tests before you buy a new one
http://www.thirdgen.org/techboard/lt...g-problem.html
Old 04-25-2010, 04:28 AM
RS2SSxLS2's Avatar
Default Lq4
Hey man im doing the same swap into my 95' camaro. Can you send me some pictures of your build and any info that might help me out? Did you ever get that problem fixed?
Thanx
Brandon
Old 05-30-2010, 01:57 AM
SmokeU's Avatar
crank sensor...........what tune are you using i got mine startednice idle until full temp kicks in idle is rough on a stock ls1 pcm. do you think a predator would work or hp tuners..
Old 05-30-2010, 05:38 AM
poconojoe's Avatar
Why aren't you using the LQ4 PCM? Is it because, the Vats doesn't let it run? If so email or message me
I'd get EFI Live, if I was buying something
Quick Reply: I need help !!!lq4 conversion
