Need adivce on coil over spring rate.....
Old 04-03-2010, 11:45 PM
QucikSilver's Avatar
Default Need adivce on coil over spring rate.....
I am fixing to order the Hal R series front and rear coil over kit and need to know what spring rate people are using on the front. It is going on a 2000 WS-6. I was thinking 275 LB but I am not sure...
Any input would help.
This is a drag car only if that helps
Thanks
Old 04-04-2010, 10:49 AM
Quick_Z's Avatar
I'm going with the same set up on the front, i don't DD my car so i went with 275# springs, not sure what weight springs needed for the rear.
Old 04-05-2010, 01:42 PM
Thanks for the input. I never actually thought about changing the springs on the back. I think that I have pro kit or a drag launch kit on the car now. I was just going to leave the springs on the back of the car and change out to the HAL's on the rear.
Quick Reply: Need adivce on coil over spring rate.....
