2000 Trans Am, 4 Knock Sensor Codes, Need help Fixing...
Old 04-04-2010, 05:34 PM
1Ls1's Avatar
Exclamation 2000 Trans Am, 4 Knock Sensor Codes, Need help Fixing...
i got a 2000 trans am, i replaced the ls1 manifold with an ls6, got the computer programmed. ever since it was throwing 4 knock sensor codes for low input or bad sensor. so i replaced both knock sensors and harness. still same problem after clearing computer...dont know what to do next...
Old 04-04-2010, 05:57 PM
bossz28-1's Avatar
i had a problem at the connector on the main harness check and see if u r getting a good conection
Old 04-05-2010, 04:37 AM
1Ls1's Avatar
which connector is it
