lavoy
04-04-2010, 08:40 PM
I finally got a half decent pass that didnt break a axle this weekend, it wasnt a perfect pass as the stereo flew out when i hit second and pinned the shifter in second so i was past my shift point by the time i got the stereo out of the way so i could hit third but other then that it was a great hook on the line and the car pulled smooth. the motor is a high miles junk yard take out 98 ls1 the only thing done to it is arp rod and head bolts and ls6 valve springs, it has the typical pre 99 oil consumption and ring flutter on decel but other then that it runs good. The turbo set up is custom made and uses a t72 turbo running 9 psi and 93 octane pump gas. the time slip break down is 1.4 60ft 6.6 1/8th at 103 10.3@ 136 1/4
http://www.youtube.com/watch?v=KNFUBJ3eN-M
