Will a 99 6spd bolt up to 93 Chevy 350?
Old 04-04-2010, 08:45 PM
Carter01's Avatar
Default Will a 99 6spd bolt up to 93 Chevy 350?
Quick question, in the process of swapping my car (99 Camaro Ls1/M6) over to a Th400. I have a guy wanting to put my tranny in a S-10 with a built Chevy 350 out of a 93 Chevy truck. Basically took out the 93 model 350 and completely built the motor then sold it to my friend.
Can anyone confirm if the M6 will bolt up to this motor?
Thanks in advance!
Andy
Old 04-04-2010, 08:54 PM
mx5.7's Avatar
You will need a 0.5" spacer. McLeod sells them.
Old 04-04-2010, 09:12 PM
Carter01's Avatar
So the tranny will bolt right up with no problems?
Ok, I assume this is the spacer needed for the clutch? Elaborate please, just don't want to give any false info, good friend of mine wanting to buy the combo.
Old 04-05-2010, 09:39 AM
85MikeTPI's Avatar
The LS1-T56 will need one of the below scenarios to bolt up to a GenI SBC/BBC:
-Conversion Bellhousing from Quicktime/McLeod/etc.
-Adapter plate to mate T56 to older Muncie/T5/T10/etc. bellhousing
-Swap over Bellhousing/Mid-plate/Input-shaft from a LT1 T56
Each method will have additional FW/Clutch/TOB issues to address depending on appliction.
Old 04-06-2010, 10:28 AM
Carter01's Avatar
Thanks for the replies!
So is this the final word? Does anyone have any other experiences or different routes to make this swap work?
Quick Reply: Will a 99 6spd bolt up to 93 Chevy 350?
