Fueling & Injection - Need help asap not getting fuel
Bo's 98 TA
04-04-2010, 08:46 PM
Ok I just got through puttin a stall in my tranny today, and now the car is not getting any fuel at all. I took the intake off to get to the top two bolts on the bell housing, but I have went back several times to make sure everything is pluged in. I replaced the relay, and checked the pump fuse and all is good, someone please help me.:bang:
Nasty N8
04-05-2010, 11:55 AM
Did you disturb the ground wires at the back of the pass cylinder head? Are you getting power at the pomp when you turn the key? How long did it sit for the converter?
Bo's 98 TA
04-05-2010, 12:04 PM
It set from friday to sunday, and the ground is good and the pump is not making any noise. Is there a certain way to check for power at the pump.
Nasty N8
04-05-2010, 12:08 PM
Volt meter on the gray wire at the tank should have 12 volts when you turn the key on for a couple seconds. Or unplug it and apply power and ground to it should kick the pump on.
Bo's 98 TA
04-05-2010, 12:18 PM
My battery gauge on the dash is not reading but the car will crank over but no fuel, I was told that my computer my have spiked?
Bo's 98 TA
04-05-2010, 06:15 PM
The ground on the back of the head is good to what else can it be.
Bo's 98 TA
04-06-2010, 03:11 PM
Got it fixed
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
