SES light, p0430 code
Old 04-04-2010, 09:10 PM
rdowens91z's Avatar
Default SES light, p0430 code
Hey guys, I have a 02 SS camaro, all stock besides an slp catback. the ses light came on and i read the code...came up as a p0430 which is catalyst effeciency below threshold bank 2, as far as i know this means that the passenger side downstream o2 sensor is reading that the cat isnt working properly, also could be the sensor acting up. i cleared it and it came back on within a few hours. any info on this would be greatly appreciated! Thanx in advance.
Old 04-04-2010, 09:22 PM
00ssmg's Avatar
i have never seen where is was the o2 and not the cat. if you have an efficence code change the cat. these are warrantied for 8 years or 80000 miles through the dealer. just check production date and see if you are with in the time frame
Old 04-05-2010, 11:23 AM
rdowens91z's Avatar
the car was manufactured 2/02, and it has 54,000 miles on it. so basically im 2 months over the time period right? and how do i know if my cat just isnt doing its job or if it is clogged? it seems to be running fine...no hesitation, good throttle response. thanx
Old 04-05-2010, 01:55 PM
2slow2flurry-ous's Avatar
I know this sounds weird but when my code came up for bank one, i ignored it because I'm about to install some long tubes. Well I decided to clean my k&n in my slp lid one day and magically the code has never come back.
Old 04-05-2010, 02:04 PM
94'BLKBRD's Avatar
I think it was extended to 100k miles. My brother just got his cats replaced on his 01' Trans Am with 99,860 miles. Check your local chevy dealer.
Old 04-05-2010, 02:09 PM
yeah it was extended to 100k on the cats I was informed by service tech at local gm stealership.
Old 04-05-2010, 08:33 PM
rdowens91z's Avatar
cool ill check that out, and ill clean my k&n as well and see what happens. thanx guys!
Old 04-06-2010, 08:21 PM
98pontiac's Avatar
A cat is meant to "outlive" the life of the vehicle. when they go "bad" the way the engine runs or ran, make the cat either get contaminated with coolant, or the engine was rich and burned/melted the cat together from being so hot. Any shop will not be able to touch that converter until it is over the "8 year 80k mile" but before you replace the cat, investigate the engine performance, because there is 100% chance there is a problem or WAS a problem with how the engine is running.
Old 04-07-2010, 01:39 AM
94'BLKBRD's Avatar
So youre saying that all the LS1 f-bod's that have had their cats replaced, even the ones covered under the recall had engine problems that lead to bad cats?
Old 04-07-2010, 11:01 AM
92SilverSHO's Avatar
The cat is bad, had the same problem, car was under warranty and had it replaced, no problems since but i don't have cats anymore.
Old 04-07-2010, 01:47 PM
ArkBird96's Avatar
It's the cat. You can change the O2 sensor and see if that fixes it, but it probably won't Both cats are a PITA to replace, so it might be better for someone to do it for you if you don't want to spend 2 days doing it like I did
Old 04-07-2010, 03:52 PM
joecar's Avatar
The catalyst monitor test involves the PCM manipulating the AFR and measuring the response time of the after-cat O2S wrt to the pre-cat O2S... if the response time is quicker than the threshold then the test fails and the PCM turns on P0420/P0430...
If the rear O2S was bad then its response time would be large, so the catalyst monitor test would pass... (no P0420/P0430).
For a bad rear O2S, the test that would fail is the rear O2 insufficient activity test (P0140/P0160).
Old 04-07-2010, 10:48 PM
94'BLKBRD's Avatar
Isn't only like 5-6 bolts per cat to replace? How did it take you 2 days?
Old 04-08-2010, 01:36 AM
joecar's Avatar
His 6 bolts may have been rusted up alot...
Old 04-08-2010, 10:09 AM
rdowens91z's Avatar
yea im thinking its the cat too, well it goes to the dealer tomorrow so we'll see what they say...hopefully its covered under warranty or else it looks like im going to eliminate the cats altogether. is it safe to be driving around with it the way it is?
Old 04-08-2010, 01:14 PM
ArkBird96's Avatar
It took me two days because I am a and joecar is correct, the nuts and studs on the manifold side were rusted as heck. Also, I made the mistake of not putting Liquid Wrench on one of the nuts and just trying to brute force it off. Broke the stud and had to drill it out!
@ the OP, if you are going to do this yourself, save yourself a lot of time and Liquid Wrench those nuts before you try to muscle them off! Yes, it should be OK to drive it like that as long as it isn't bogging down or exhibiting any of the other symptoms of a clogged converter.
Old 04-08-2010, 09:22 PM
98pontiac's Avatar
Yes sir that is 100% correct. I catalytic converter has no moving parts, and has not purpose but to chemically react to different gasses and convert it into not so harmful gasses. for it to go bad is has to either get contaminated, or get so hot that it melts.
Old 04-09-2010, 02:10 PM
rdowens91z's Avatar
Dealer wont warranty anything because it is a month out...oh well, so i gutted the cats today...where would be a good place to get o2 simulators?
Old 04-09-2010, 02:50 PM
91RS383's Avatar
You're local tunning shop.
The O2 sims are not that reliable. Most people will tell you it's better to have the test eliminated while having a performance tune done. Either way you go, if you leave the rear O2s in place everything will "Look" legal.
Old 05-12-2010, 08:17 AM
SoJersey05V's Avatar
I just threw this code 20 mins ago, 05 ctsv. Just did kooks and HF cats.... bad cat or need tune to set the maps of O2s wider?
Quick Reply: SES light, p0430 code
