replaced slave cylinder and still have no pedal @ high RPMs
Old 04-05-2010, 01:41 AM
mylittlez06's Avatar
Default replaced slave cylinder and still have no pedal @ high RPMs
when I bought my 2000 SS it had pedal pressure issues, I figured it was the slave so I pulled the trans and replaced it with a new stock replacement and put a tick shift remote bleeder on it, if I did any full gear pulls on it as soon as I shift into the next gear I miss it cause the pedal just goes to the floor, which it was doing before, would this be cause my a bad master cylinder?.......need help and I wanna go to the track this friday....thanks
Old 04-05-2010, 02:30 AM
ArcticMissile's Avatar
I just installed the Tick M/C because I am having the same problems as you. Mine is still doing it after the Tick M/C install so replacing the slave is next for me. It's either the M/C or a pressure plate/clutch issue. I would change out the M/C first since you dont have to drop the trans and see if that fixes it.
Old 04-05-2010, 03:18 AM
it has a newer clutch in it, I looked at it when I replaced the slave cylinder, IMO it has to be the M/C, and in your case you should either do the drill mod or a slave, cause a pressure plate wouldnt affect the hydraulics, it would just slip, but thanks for the advice
Old 04-05-2010, 03:24 PM
I would just for the Tick M/C it's the logical next step.
Old 04-06-2010, 03:02 AM
I dont have thatmuch cash, im laid off, im just gonna buy a stock one
Old 04-06-2010, 12:15 PM
I feel ya bud good luck on the job search. The Tick is just a luxury the gm replacement will work just fine.
