****VIDEO**** - Clutch SQUEAL Noise...
So, I've talked to a few people and they say that "puck" designed clutches sqeal or make noise by nature... nobody has heard my car, and they just say this by what I describe to them. So I finally got a video together tonight when I was leaving my work (I work graveyards). Started the car up from cold, let it warm up for about 5-10 minutes then hit record on the video camera...
So guys tell me if this is normal or not... the car seems to perform fine and the clutch works fine as well. I have no issues really, except for this loud *** annoying noise coming from feathering engagement into first gear... It's REALLY EMBARRASSING!!!
http://www.youtube.com/watch?v=kfJsgZVQN7Q
LS1TECH Sponsor
thats the normal puck noise i hear from cars.... although yours is on the loud side.... unfornuately it appears that the material that centerforce uses on the DFX puck disc is pretty aggressive... if the car drives good i wouldnt worry about it unless you want to spend some cash and replace the clutch..... if the noise gets worse then that i suggest a teardown to see whats going on
hmmm thanks guys, that makes me feel a little better. I just needed a video so everyone could see and confirm what I've been told. I just couldn't comprehend that this would be "normal" for a clutch to do
Ryne, I'll probably eventually spring for one of those Monster Clutches at some point... it's rough seeing as it'll be like my 6th or 7th clutch swap. It's getting old trying to find the right one. Glad you chimed in to ease my nerves on this particular noise...
that's what's sooooo damn aggravating about it... I don't wanna know how much money I've spent on the labor alone in the R&R of the clutches and tranny. I've tried cheap clutches and I've tried $1500 setups... The car NEVER sees the track, and I drive it pretty damn conservatively. So I don't know where I'm going wrong.
I guess just the nature of the beast...
sounds like your squeezing a rodent inside your bellhousing... although on my old C5 vette that same noise told me something was wrong with the clutch since, to me, no clutch should sound like that. I tore it down and saw the clutch was shot and replaced it with OEM stock one and the noise was gone.
that's a lot of clutch/transmission work/swaps and would have figured you would have gotten it right by now. but to me that's the sign of a bad clutch, but if it grabs and doesn't slip I guess your good
YES!
My clutch squels a little bit when the clutch is cold and I take off slowely through 1st. Once ingaged it is fine and doesnt squel once it is warmed up.
So why is that? Just currious, because my clutch was making alot of noise after it was installed. They did a crappy job of bleeding it so I was never really able to get on it. After I bled the **** out of it, it works great and I am now able to really get on it. A couple of days ago I noticed that it's pretty quiet also..... I didn't think the bleeding had anything to do with it... WTF
