Modding a Truck harness help
I am in need of someone to mod my truck harness. The harness is out of a 01-02 Silverado. I am not to keen on the electronics and wiring diagrams and have looked at several write-ups on here. I still can't figure it out and would rather pay someone to do it.
I am in the middle of doing an LS swap with a Lq4 shortblock, 5.3l heads, LS6 intake and style injectors. The tranny will be a 4l80e. I also have the the truck pcm as well that needs to be flashed. Before I forget, its for a 97 camaro Z28.
Please let me know with any ideas, comments or if other information is needed.
^^ he is correct. I did mine for my rx7. what6 i did was get a sheet of plywood that you can lay the harness on. the remove the coverings. lable the connectors and take out what you dont need. in GM harnesses all the pinks and oranges are 12v switched and constant. Get yourself a repair manual for the yearm truck harness you have incase you get lost and there also is a lot of info on line as well. good luck, you can do it .
I did my own and I am not to far from you.. PM me if you want any help or have questions.. I might even be willing redo the harrness for you.. but I do have an other project I am working on also..
