biggest needle bearing in a t56 is where??
ok so when i got my rebuild kit i basically submerged everything in atf. im almost done with the rebuild (just reverse and some odds and ins left to go) anyway i have one needle bearing left in the fluid dish, and i have no idea where it goes. im almost posiive i didnt leave a bearing out during the rebuild. i could have possibly left the old one in by accident. the bearing i have left over has a white casing and is 2 inches in diameter. its a pretty good sized bearing. where would this go?
http://www.ttcautomotive.com/English...ice_Manual.pdf this should help you out
im thinking maybe i wasnt thinking and used an old one instead of the new one. ill have to count the old bearings and see if i come up with the right number. if i used an old one imma just leave it in there rather than
