Drag Racing Tech
LS Motor plate & Mid plate problem
Old 04-05-2010, 08:37 PM
1Bad2's Avatar
Default LS Motor plate & Mid plate problem
1) When running front plates with ls motors what are you guys doing with water pump pulley moved out thickness of plate? Out to far for crank pulley. 2) Mid plate & Ultrabell hit upper 4 bolts on rear main housing. Could change hex head bolts to round head cap screws for problem 2, but don't want to have to use electric drive for water pump. Can pulley be changed? Thanks, mike
Old 04-05-2010, 09:22 PM
Race your car!
JL ws-6's Avatar
Most people, once they put the motor plate on are already on an elec water pump.. I'm sure there's a way to get it to work. I'd guess this is a madman question, I'm sure he's done it already.
The rear sitation, I'd swap to a cap hex head bolt like you're saying... not sure what else can be done there.
Old 04-05-2010, 10:52 PM
1_bad_ss's Avatar
I would think you could just mill the pump down the same thickness of the motor plate
Old 04-06-2010, 05:26 AM
LS1Tech Sponsor
MADMAN's Avatar
The water pump doesnt matter as the pulley is plenty wide enough to take the belt out and extra 1/4". You will need to take a die grinder and notch the bell housing for the bolts.
__________________
www.madmanandcoracing.com
225-343-9029
Old 04-06-2010, 10:07 AM
Race your car!
JL ws-6's Avatar
Madman you wouldn't happen to have a picture of what you're talking about with the grinding would you? It would be helpful for people to see this.
Old 04-06-2010, 02:44 PM
1Bad2's Avatar
Never even considered milling the pump. Thanks 1_bad_ss I think I'll try that. The rear I'll try different bolts, just can't bring myself to grind on my Ultrabell (yet). Thanks MADMAN & JL ws-6 I appreciate the help.
Old 03-23-2021, 06:07 PM
Bmw_shenanigans_l59's Avatar
How did milling it work out? No news is good news?
Old 03-24-2021, 04:14 PM
Tony Corley's Avatar
You might get an answer, but the thread is 11 years old. It makes sense that it would work, but since I haven’t done it personally, can’t verify
Old 04-07-2022, 09:49 PM
Low Racing Products's Avatar
Default Just did this
ALl of my front assembly mounted to the heads. The only issue was the tensioner which mounted to the water pump. I milled a 1/4" from the back of tensioner housing. Worked out well.
Quick Reply: LS Motor plate & Mid plate problem
