C5 Brake Conversion Parts List?
Old 04-05-2010, 08:52 PM
Patsy57's Avatar
Default C5 Brake Conversion Parts List?
Anyone happen to have a list of parts required with part#`s or without to do a C5 brake conversion for an F-body? I understand you can buy a kit with all these parts but I was just curious how much it would be if I sourced my own. That being said If you have a parts list please post it or pm me.
Thanks
Old 04-07-2010, 09:11 PM
fast377's Avatar
Copied from trackbird over on frrax (if all you have are the brackets, you will need...):
GM Part # / # needed / Description
12530682 / 1 / Caliper, Guide pin bolts included (standard gray C5)
12530683 / 1 / Caliper, Guide pin bolts included (standard gray C5)
88895128 / 1 / Caliper, Guide pin bolts included (red Z06) OPTIONAL
88895129 / 1 / Caliper, Guide pin bolts included (red Z06) OPTIONAL
10445856 / 1 / Right Rotor (standard factory fitment)
10445857 / 1 / Left Rotor (standard factory fitment)
88925547 / 1 / Right Delco Durastop rotor, lower cost OPTION
88925548 / 1 / Left Delco Durastop rotor, lower cost OPTION
12455799 / 2 / Pad abutment bracket
10333772 / 2 / Front caliper brake hose
12530697 / 4 / Pad abutment guide pin
12530703 / 4 / Guide pin boot
22163795 / 2 / Banjo bolt
10139097 / 4 / Banjo bolt copper washers
Quick Reply: C5 Brake Conversion Parts List?
