Not even sure if it's an appearance mod, but...
I did the "Automatic Headlight disable" tonight. At first I was alittle intimidated by it...wasn't sure how it was going to go...but it literaly took me 5 minutes and everything works great. I've got 3500K hids for fogs and Halos. Love it.
Copy & Paste Moderator
Auto Headlight Defeat: https://ls1tech.com/forums/7096661-post8.html
Its in the Lighting FAQ: https://ls1tech.com/forums/appearanc...hting-faq.html
I'll get some tonight and upload them...
It was super easy...
If you have a TTop car take the passenger side t-top out and unscrew the 2 screws and the pillar...pull that out and just pop up the passenger of the upper dash pad. You can't miss the Sensor, it's right there...I used a scotchlock and squeezed it with a pair of wire crimps. Turned key over it worked...put everything back together...took literally 5 minutes.
