I have a 98 pcm,what are my option for my twin turbo build?
i have a 98 camaro that i am installing a 441 LSX twin TC70mm set up. yes it is a 6spd street car. what are my options?I heard that 98 **** sucks. well i bought a 99 pcm what all do i have to do to make it work with my cluster or is there a better option?thanks for any help
Your primary issue is the fuel gauge. You will need to use a fuel system module from an express van file to get that working correctly. Not sure what software you use but I'm pretty sure that EFI Live can swap modules. Other than that you will have to re-pin your harness to work with the '99 - '02 PCM. If you have ASR, it will not work and the light on the dash will be on.
Todd
Todd
so i can keep my 98 pcm? i heard u cant go past 15lbs of boost with the 98? If i can keep my 98 then does anybody have one? I lost mine,but i have a 99 laying around.
my car is a 98 and the comp. will only read around 14.7 lbs of boost....so you really only have two options if you wanna go over that boost level...if you have the cash and wanna upgrade just go with bs3 system....or like you said switch to the newer pcm....so far i have had no problems out of my car and i drive it on a daily basis..
I would switch to the 99+ PCM.
With all the money you have invested in that setup the cost of the PCM swap would be "chicken feed".
The benefits are a faster processor in the PCM and the ability to use a COS.
Converting a 1998 PCM to 1999+
http://www.chipsbyal.com/convert98/
LS1TECH Sponsor
To work properly you'd need to repin the harness have the fuel segments changed, etc. Its a good amount of work for what you get out of it. Our software offers a 2 bar custom operating system that has been proven good for well over 600hp so unless you plan on boosting to 16+psi sticking with the 98 pcm and our 2 bar custom os you should be just fine.
