Sponsored by: DashLynx
Hid bulb for stock firebird
Old 04-06-2010, 11:38 AM
jorgez28's Avatar
Default Hid bulb for stock firebird
Guys I wanted to know what is the hid bulb size for our stock wiring. Basically i want to open up the stock housings and insert hid bulbs, but I want use the stock wiring to the ballast. Thanks
Old 04-06-2010, 11:44 AM
staticx57's Avatar
You would need to get a sealed beam conversion kit such as eurolights. But I highly recommend getting projectors such as the BLS kit.
https://ls1tech.com/forums/appearanc...-retro-gp.html
Old 04-06-2010, 11:55 AM
jorgez28's Avatar
I know but I do not have the money for either but I do have to bad headlights I just wanted the bulb size like 9006, what is the correct size for a bird
Old 04-06-2010, 12:52 PM
ls1jorge's Avatar
Just UP GRADE SAVE MONEY !
Go to http://www.eurolamps.com/eurolamps/c...headlights.htm
& buy the conversion kit to make your headlights go from sealed to the newer style bulb. Then buy the bulbs from the website I showed you ^. This way you can simply plug in the bulb into the new housing supplied by euro lamps and makes the install much easier.
http://www.ddtuning.com/index.php?p=...=102&parent=85
For the Headlights ^ the bulb # is H7 and for the Fog Lights series 880
My frd (Ws6Kid) used 55w 8k headlights, & 35w 6k Fog lights
Old 04-06-2010, 01:05 PM
Chaos07's Avatar
ya just do the conversion from eurolamps...honestly its the best way 2 go if you dont have 500 to do the badass BLS kit i wish i had the money to do that but i jut ordered my kit from euro lamps n im waitin for it to come in n intall it
Old 04-06-2010, 03:27 PM
jorgez28's Avatar
Thanks so if I get the eurolamps kit then the h7 bulbs will fit the stock pin type connector
Old 04-06-2010, 08:00 PM
Danny2tek's Avatar
Check out post # 731... Better quality then Eurolamps and last time I checked cheaper!!
https://ls1tech.com/forums/pontiac-f...l#post13145552
Old 04-06-2010, 09:22 PM
99'CajunFirehawk157's Avatar
Cool
I had the eurolights "conversion kits"
Go to www.eurolamps.com/eurolamps/camaro_headlights.htm
& buy the conversion kit to make your headlights go from sealed to the newer style bulb. This way you can simply plug in the bulb into the new housing supplied by euro lamps and makes the install much easier.
www.ddtuning.com/index.php?p=product&id=102&parent=85
Old 04-06-2010, 11:26 PM
jorgez28's Avatar
Thanks I like those housings
Old 04-07-2010, 07:41 AM
ls1jorge's Avatar
^Oh yea the housing looks alot better! I'm leaning towards LMC now!!
Can I use the LMC housing to go with the ddmtuning??
Old 04-07-2010, 08:07 AM
Danny2tek's Avatar
Yea just get the 9006 bulb kit.
Old 04-07-2010, 08:14 AM
ls1jorge's Avatar
ok, & what how many watt should I use for my headlights 35 or 55? Do you got ur self LMC too?
Idk jack about headlights & bulbs LOL
Old 04-07-2010, 08:24 AM
Danny2tek's Avatar
My car currently has the autoptiks kit(same quality as eurolamps) with H7 bulbs, but the reflective inside coating is coming of. Yesterday I ordered the LMC's and the 35 watt 9006 HID kit (DDMtuning)
Old 04-07-2010, 08:42 AM
ls1jorge's Avatar
Ok thats good man I wonder how many ppl used LMC housing for there firebirds,
You have a direct link to the housing LMC purchase, low & high beam?
Old 04-07-2010, 09:01 AM
Danny2tek's Avatar
PM sent....
Quick Reply: Hid bulb for stock firebird
