trans am max effort
Race your car!
OK your hood rails, what are they and where did you get those?
I like everything I see, the rear tunnel notch I like alot, I'm contemplating making that removable, but at this point I think it's staying permanent. The rear floor being flat is nice too, makes a good place to put a muffler if you have to run them.
The shock tower cutting is a little extreme, but if it's stiff then cool. I know that's how alot of the outlaw 10.5 cars I have seen are done, not sure if I want to go that far though... that's alot off and not much left up there.
What's the car weigh now, or should I ask, what does it weigh compared to all that being in there still?
Get rid of the stock spindles too, they're heavy as ****, you ditch those for a LW one and you'll lose another 50 lbs off the car.
Race your car!
Wholly **** that motor was fucked up! That's some serious bend in the rods, what kind of rods are those? I haven't seen anything that bad in a while, piston took a beating too pretty bad, crank's probably screwed too I'd guess.
My motor's for sale if you're looking for a decent piece to run while you're fixing your other one... went 9.50 with a single 65 jet @ 3350. You're probably gonna be tipping the scales around the 2800 mark with what you've done there I'd guess, that and a single plane/fogger, say with a 28 to 30 jet would easily run well into the 8's on 1 kit I'm positive of that.
my goal is 800 lbs off the car.??? we will see
Race your car!
What did it weigh before?
I'd say that looks to me, like a 2850 lb raceweight. You've taken a bunch of stuff farther then I was going to and I KNOW that with an alum block motor and the 8.50 cert it was gonna be about 2900, with a 240 lb driver.
Check my motor for sale thread... might be a good way to get ya by while you're working on the other motor.... I want to move this thing, and you probably have an intake that would work and don't need the waterpump... price is broken out without that stuff, lemme know.
LS1Tech Sponsor
The Firebird set up is $800.00 with all the hardware and support rods.
http://www.madmanandcoracing.com/sho...spx?itemid=204
We are working on the Camaro now.
Nice lookin peice!
