Where to get the tool to pull the pins out of the coil connector?
Old 04-06-2010, 04:11 PM
lt1camaroman93's Avatar
Default Where to get the tool to pull the pins out of the coil connector?
I am in need of the tool to pull the pins out of the coil connector, any clue where to get one? I'm putting a two step in the car and I don't feel having a large enough hole in the firewall to pass the connectors through. I would like to take them off, feed the wires through, then put them back on.
Old 04-06-2010, 07:35 PM
poconojoe's Avatar
Which coil connetor the ones on the brackets or the ones on the coils?
Old 04-06-2010, 11:00 PM
Inbred's Avatar
I think he means the piNs on the wire ends at the connectors. He wants to pass the harness through a hole in the firewall, but the connector doesn't fit. So, basically he needs something to help him repin it.....
Old 04-07-2010, 05:19 AM
Pop N Wood's Avatar
http://www.repairconnector.com/produ...-3-Pieces.html
Radio Shack may have what you need also.
Old 04-07-2010, 07:36 PM
Hmm. I have that set, didn't look like it would work, I'll have to give it another look. Thanks guys.
Old 04-07-2010, 10:13 PM
poconojoe's Avatar
It will work if you're trying to remove the pins from the inline connector
Quick Reply: Where to get the tool to pull the pins out of the coil connector?
