coolant steam tube?
Old 04-07-2010, 01:11 AM
reamo04's Avatar
Default coolant steam tube?
where are you guys putting them?
I know with LT1's its popular to tie it into the upper radiator hose. Just wondering what you guys are doing with your LS swaps.
Old 04-07-2010, 07:15 AM
1976CamaroGuy's Avatar
Upper radiator hose with a splice is where mine is going
Old 04-07-2010, 07:28 AM
46Coupe's Avatar
The consensus here is to tie into the upper radiator hose
Tap the top of the water pump and run it there
Weld a bung on the radiator and attach it there
Old 04-07-2010, 07:50 AM
Old Geezer's Avatar
Try a search.. this is discussed frequently.. You may get a variety of solutions.. pick the 1 U need.
Old 04-07-2010, 09:41 AM
Pocket's Avatar
Its supposed to go to the highest point in the cooling system. Several people including myself have had success with a Tee into the heater core lines instead
Old 04-07-2010, 10:28 AM
IHEARTLS1's Avatar
Thumbs down
pocket, what lower radiator hose is that? what car is it in?
Old 04-07-2010, 11:40 AM
bczee's Avatar
my aftermarket Radiator had a bunt in place, so I was able to use a fitting and route the steam hose directly back to the radiator.
Old 04-07-2010, 09:01 PM
Pocket's Avatar
Car is a 92 firebird and the hose is for a 90 Ford F250 7.5L. I trimmed both ends to fit
The bung on the radiator is the ideal situation. If you have an alum radiator and access to a welder, its a great option. Same for people who go with the 4th gen radiators
Old 04-07-2010, 09:17 PM
IHEARTLS1's Avatar
i just got my hose to fit. 2007 cadillac escalade. i trimmed 2-3 inches off the one end and it fits perfect.
Old 04-08-2010, 09:52 AM
clm69z28's Avatar
My radiator had a bung in it also so I followed the upper rad hose and a little channel between the rad and support to the bung fitting. It is good to get it to the highest point to make sure the air gets out of the engine.
Attached Thumbnails coolant steam tube?-p1010276.jpg   coolant steam tube?-p1010330.jpg
Old 04-08-2010, 09:59 AM
Steve1969LS1's Avatar
I run my coolant tube into the top of my water pump.. it looks good and works just fine.
Old 04-08-2010, 11:32 AM
Jimbo1367's Avatar
Default steam vent
Thats what I am going to do too. I plan on trying to epoxy some clips to hold the steam on the bottom of either the upper hose or intake tube. Going for invisable
Old 04-14-2010, 12:40 AM
clm69z28's Avatar
I thought of using some large diameter heat shrink that would go over the rad and steam hose to conceal it, but didn't try it. Or even some of that woven hose protection material would work too.
Quick Reply: coolant steam tube?
