You probably want to get your tune adjusted though. The LS6 intake is much more efficient up top. The 98s have a lot of timing at WOT from the factory; much more than your engine needs after an intake swap to an ls6.
As long as you do not have a strict Visual Inspection Process. I see no Issues. If stock, your fine. Tuning should def be done as it will make the car better.
