Drag Racing Results - Not so swell first time at track :( advice?
shane2390
04-08-2010, 12:06 AM
I decided to take my 02 Z28 to the track for the first time tonight. It is my DD and it has just under 80k miles. It has Slp loudmouth, UD Crank Pulley, and Msd wires. It is a M6 also.
I never have a problem missing a gear but I guess because it was my first time I couldnt seem to nail 3rd. I missed completley into 5th the first run.
Second Run It hestitated to go into 3rd, and the 3rd run I took my time to make sure I didnt miss it. Do you think a aftermarket shifter would help? I have the stock t56 shifter with the bulky ball knob
I am on previous owner supplied 225/45-18's, I have stock wheels with no tires, I think when it is time I will buy tires for the stock wheels so I can get a wider tire. I dont have a lot of money, and this is my DD so I dont want to do any real hard launches and break my rear. but I just really didnt expect 14's...
Heres my crappy 1st run ( I AM 355)
http://i166.photobucket.com/albums/u113/shane2390/345.jpg
Here is the 2nd Run
http://i166.photobucket.com/albums/u113/shane2390/346.jpg
Here is my 3rd run
http://i166.photobucket.com/albums/u113/shane2390/347.jpg
Here is a video of the last run ( dont mind my gf, she is a ra-tard.
http://www.youtube.com/watch?v=9J82C9EVXPI
qwk93ta
04-08-2010, 06:15 AM
Yes, get an aftermarket shifter....I like the Pro 5.0, it will make a huge difference.
96lt1m6
Yes a shifter will help but the main thing is practice your launches and shifts. Its hard to get a good 60' w/radials and an M6 but can be improved upon..
Pro 50 (mechanical feel) or B&M ripper (smooth)
shane2390
04-08-2010, 10:05 AM
Yea I hardly ever miss 3rd on the street, but i will look into one thanks
greatskiiiier
04-10-2010, 10:53 AM
shifter, tires, and PRACTICE!!!
also you shouldnt be going into fifth, so you're def short shifting
S8ER95Z
04-14-2010, 04:04 PM
My guess is you need the drill mod... if I shift too fast I can't hit 3rd period. I normally have to delay my 2 to 3 shift slightly to get it to work.
Something is very strange... where was this at? Something is telling me this is a high altitude track or something is wrong with the car... your MPH is very low.
KCFormula
04-14-2010, 05:33 PM
You gotta get that 60' down. Don't worry about the rear end until you start launching on slicks and put a ring gear with thinner teeth in there. Slip the clutch a little and be agressive with the throttle. Even on 225s you should be able to pull an easy 2.0.
doublea87
04-14-2010, 05:40 PM
dont feel bad man. last night was my first time at the strip and my best was a 14 flat. i could only make 2 passes tho on the night (big lines) but im going back for sure to work on my launchs. my 60' times were around 2.3 :(
Villain281H
04-14-2010, 08:21 PM
As mentioned, practice will ultimately help out more than throwing a bunch of mods at it. But the mph does seem a little low. Check all normal maint. items like plugs, filter (air and fuel), etc.
Derek
lemons12
04-14-2010, 08:32 PM
EDIT: DUH! :lol:
Honestly... At my local track (1/8) that is what most stock 6 speeds run... Definitely need traction and practice launching but it is about on par for first trip to the track.
Detroitmuscle
04-14-2010, 08:41 PM
I think he means he shifted to 5th instead of 3rd guys.
Quick SSilver 98
04-14-2010, 09:34 PM
Sunday was my first time to the track and I found out A. I need drag radials B. adjustable torque arm and C. MORE TRACK TIME LOL. I am also a M6 and I ran a best of 13.6 at 107 with a shitty 2.3 60 ft. I could not get it to hook off the line for anything and my 1-2 and 2-3 shifts spun real hard also. As for you trapping 100 you might be granny shifting and not slaming the gears fast enough you should definitely get that after market shifter it will make your 2-3 shift smoother and much faster. I also run 3rd to the finish line where im at about 6300RPM. Hope this helps and good luck.
smok'nZ
04-14-2010, 10:31 PM
i dont mean to be a dick but a 14 is giving f-bodys a bad name :( time for some drag radials and a shifter and a lid if you dont have one
itsslow98
04-23-2010, 02:08 AM
nope DA is usually pretty good around here.
Midnight02
05-07-2010, 03:09 PM
A little seat time at the track and practicing your launch will really help the times. You'll be amazed by what knocking that 60 foot time down to a 1.8 - 1.9 will do for you!
As for the shifters, I upgraded to a Pro 5.0 -- love it. It has a very firm, positive feeling to it -- you're either in gear or out (isn't slushy). The greatest benefit is that the 2-3 shift is almost linear -- meaning that you're pushing the shifter in a straight line for the shift rather than an up-over-up some more motion.
Quick SSilver 98
05-18-2010, 09:06 PM
+1000 That shifter will give you a big driver mod :)
5.0 LsX
05-18-2010, 10:42 PM
drill the slave
sticky tires
and drive it like you stole it!
NSSANE02
05-19-2010, 01:10 PM
Look into a Tick MC if you're having troubles with your shifts. That plus a pro 5.0 and it will feel like a completely different car. Also, 225/18's? Get yourself some real wheels and tires and the launch will be MUCH easier :nod:
chavez885
05-19-2010, 01:13 PM
My dodge neon had 225's on it......just sayin
XPTBSS
05-19-2010, 02:56 PM
^^ LOL
225s are crazy for that car...I would definitely get a different tire on the car and a shifter....
