Spare in Trunk Question
hey guys, so i took that big yub out of the trunk and put my spare in there. are you guys able to put the cover back on with a spare tire in there? mine doesnt fit. what gives? is there a faq on this?
thanks guys
thanks guys
but its stil going to be the same isnt it? i fliped the tire upside down but it didnt seem like it would work. i didnt even bother trying to put the cover on. i will try it tonight
Yes, the tire needs to go in upside down. The cover won't sit totally flush and will still stick up a bit, but it will go on and you should be able to screw it down tight if you push down on the plastic wing nut while tightening it down. At least I was able to do mine that way... Of course, this is assuming you have the normal 245 size tire on it. A wider tire and you're probably out of luck.
^ lol, is that the right solutin :-)
so i flipped the tire and it fits now. but im still not able to screw that middle piece down...wait, i just read the part where you said to push down. standby, i will let you know after lunch
maybe im not strong enough,..lol..its been a while since i worked out...ima have my buddy help me. but it does sit alot more flush now than it did before
When I first test fit my full-size spare I found that the wheel/tire wouldn't sit all the way down in the bottom of the spare tire well, that the tire was rubbing the sides of the well. Specifically, there was a bulge in the side of the tire well on the passenger side towards the rear - I used a block of wood and a 3lb hammer and flattened that bulge a bit. After that the spare sat down into the well all the way.
