Rossko85
04-08-2010, 11:01 PM
had this lil misfire problem around ever since i melted the plug in #7 on the
N2O last year but, changed the plugs from the TR6's to the NGK BR7EF (2 heat range colder) gapped at .035 mind you im boosting now....
I have read all the post it feels like that is related to ALL the possible reasons for misfires etc....I have tried just about everything; including consulting several professionals. Among the ranks would be Mike Norris and some other repitable LSx folks. Lots of good info but, only speculation at this point becuase of everthing I have tried as far as testing comes back in speck!
So....here I am...so your familiar with the car...
It is an LS4(5.3L) step child LOL!! FWD I KNOW I KNOW...BLAH BLAH lets get that out of the way LOL...It has a MP T70 Rear mounted...only engine modifications are a 160* tstat and 2 heat range colder plugs....the car is transversely mounted obviously and is on manifolds that come into a single downpipe with no CAT but a race pipe, no ressy and straight into the turbo...running 69lb injects with a walbro 255 in the tank and running a catch can...
car is not a kit car from STS...we bought some of thier solutions to make our parts and design work...so this is the world's first RMT LS4...
Now, it has an oil pump return system just as the STS cars do as well....returns the valve cover...
Gotta tranny cooler and thats about it.....
it is an N2O car with an FJO on her...but not running N2O just yet with the turbo...but did run it last year...hints the 12 sec club LOL...
so what ive done so far:
Changed plugs........not it
regapped...............not it
switch wires...........not it
switch coil packs.....not it
switch injectors.......not it
running comp test....not it: all cylinders have compression
Leak down test........not it: all in specks
VC pull/valves/sprng..not it: all seated and looked good, no apparent breaks
cranking comp test...SOMETHING!!: had a lil leak bye from the spark plug hole on my number 7 but, went away as they threaded plug in tighter?
I think i cross threaded the plug sometime back last year with all the misfire problems after the N2O and with all the plug pulling etc....but the plug still threads properly....NOW..i did notice I have a Oily/black residue coming out of the spark plug hole in the head....
we did get some flashing SES's on the dyno....misfires are isolated on #7 and only occure at idle....and sometimes NONE AT ALL!! its very strange...none under load at all...
I read somewhere that some guys have cross threaded the plug or plugs and got misfires and put thread loc and high temp sealant on the plug and it cured their ills due to the plug not getting full contact with the head and sealing assuring contact...this was the theory atleast and it worked!! for THEM!!
Yes, i tried it...why not...well...misfires went even more crazy and melted the crap right off!! LOL...i know..idiot me...hey, give me a break...im trying everything!!
Plug looks good in porselan but, the base ring is DARK DARK DARK which I feel and some others say rich....and yes the car is boosting a lil rich right now but, the other plugs dont look quite as dark...
car is on 8psi running 11.5afr and 15-18* of timing throughout the tune.....
no cam!! factory rods, springs, pistons, connectors, lifters...etc...all OE except for what I have listed....
Was going to take the next step and have the head helicoiled from a shop that might be able to do it on the car....my #7 is the front-driver side if looking at the car...so atleast easy to get to!!
I know...should take the head off...well, doing the best with what i have....trying to avoid that at all cost until the end...thats when Mike Norris is probably going to take a look...I live in a small apt with no tools or a garage...im limited to my back seat and trunk....this is a sad reminder of what happens when a guy that is an ethusiast that doesnt have all the resources to do it right at hand but, can make it happen LOL....
Cars getting a street/strip tranny rebuild currently to allow my FWD ass to slam it 1000 plus whp if I desired....goaling for 500 for right now...
so with the long post...just wanted no stick unturned here....Mike is saying could be a valve guide sticking the exhaust valve or holding it up a lil bit....
but really wont know until the helicoil or the head has to come off i guess....
car idle is good...power is good...not cut out or anything...VERY WEIRD...and if you do a search for residue coming out of a spark plug hole head...or use any of those words together...you only get a few post to come up...the top on is my build thread LOL!!
Help please...if you can...
