bushings for stock upper A arm
Old 04-09-2010, 11:01 AM
JFM-jr's Avatar
Default bushings for stock upper A arm
Does anyone make a delrin or free floating typer bushing to replace the rubber one in the stock upper A arm? Car is not lowered and is set up for drag racing.
Old 04-09-2010, 11:17 PM
Foxxtron's Avatar
Sam Strano had (or maybe still does on occasion) custom offset Delrin replacements, otherwise, Global West has some of their "Del-A-Lum" ones that were OE replacements (but that was a few years ago).
You can try to call both to see what's around.
Old 04-10-2010, 04:45 AM
99Bluz28's Avatar
The Global West bushings are still available.
Old 04-11-2010, 03:41 PM
leadfoot4's Avatar
Energy Suspension also makes a poly bushing for the upper a-arm.
Old 04-12-2010, 02:55 AM
sjsingle1's Avatar
if you compare a stock upper arm and a good tubular.......you will NOT put the stock back on........its that flimsy........get you a good upper arm and the bushing of your choice
