NAL3231
04-09-2010, 01:46 PM
Any one else have this problem? I have the white vinyl top and was wondering if there is a way to fix it with out getting a new top?
wrd1972
05-07-2010, 03:58 PM
No fix other than replacing it. Mine did it too.
xny1989
05-22-2010, 10:11 AM
Actually you have several options. The best one is to replace the rear window curtain - it's separate from the rest of the top. I'd do this (in fact I did) if the rest of the top is in good condition. If you're handy and have time, you only need sockets, a drill and good staple gun to do the job. A cheaper alternative if its only the glass separating from the fabric/vinyl is to get a good construction adhesive to hold them back together. I used black silicone when the bottom part of the window separated (I have a black top), but it did not work when the top part of the window separated. The glass actually fell into the car on a really hot sunny day. That's when I bought the window curtain and did the deed. This was my first time doing it, so it took some time and I actually had to redo the bottom because of some creases in the fabric. It's been about a year now and its all holding up perfectly.
